15n20 sources or alternatives
nine9jack9
Active Member
Was getting 15n20 from NJ Steel Baron, stuff is great and makes a good blade by itself. Can't seemingly get it now. So my questions are: does anybody else know where I can source it? Are there alternatives that can work? I hear it is very similar to 1070 with the addition of nickel; that being said, can I heat treat 1070 the same as 15n20? Thanks for any info.
Yes...heat treat is same. As you said...15n20 is basically 1070 without the nickel. It may actually be a bit easier to heat treat 1070 as it doesn't really need a soak. 15n20 is best with a soak.
