Von Gruff
I have been trying to find a 2 inch drum sanding mandrel and the apropriate sanding drums so I can use it in my drill press. When I have been doing the curve backed bolsters on my knives I have been holding the pinned together blosters and finalising the curve on the 2 inch contact wheel on belt grinder but there is a possibility of getting the curve slightly off square to the flat doing it this way so having the bolsters sitting block square to the drill shaft and feeding the bolster to the drum would ensure perfect square to the face curves and make fitting the handles to the curve so much more accurate. Have looked on ebay (and the chinese site where I often get things) and only seen them in smaller sizes.
Have thought of getting a madrel made and contact glueing sandpaper to it
What does everybody else use to sand inside curves and keep them square to the flat?
