CustomerServiceBeth
Super Moderator
We will start the bidding at $50.00 this auction will last for 30 days.
Donation from Justin Hamm (Black Raven Arms)
The knife is 8.5 inches of Elmax stainless steel that has been heat treated and over night cryo bathed to 61 Rockwell hardness. The surface of the blade is a glass bead blasted finish which is resistant to scratches.
The handle is a combination of stabilized walnut outer scales with black micarta inner scales and copper liners. I use West systems G flex epoxy to affix the scales.
The copper and stainless mosaic pin is custom to my knives. The lanyard tube is stainless steel.
The sheath is ambidextrous with a reversible Ulti clip XL belt loop/clip and is made from .080" Kydex.
My makers mark and company name (Black Raven Arms) are Celtic/Norse based. The mark itself is three mead horns overlaid upon each other that represent the three sips from the mead horn of wisdom that Odin took.
OAL: 8.5” Blade length: 4”
