K
koyote
Guest
I generally stay far far away from sword specific forum areas, but I'll get my feet wet here.
This is a langseax project. Someone recently told me there's a rule that a langseax can't be a sword, and MUST have a 20 inch or longer blade. Well, I'm breaking both rules!
I have been, for a few years, making and refining my "modern seax" design.
This is the regular larger model modern seax:
What I wanted to do with this one was keep my design style intact and build something...swordlike.
(A note: I do forge some, but I only forge to shape things for grinding. I mostly get my final profiles and convex grinds on the grinder. I have a very intimate relationship with my grinder. So do, occaionally, my thumbs, index fingers, and ballcaps. In this case, I didn't do any anvil work at all.)
Here's the blade after initial annealed state grinding and a 220 grit hand rub:
Overall, it's over 24 inches, the blade length itself is 17 3/4 (see, I'm breaking the RULES)
The material is 8670M, stock width slightly over 1.5 inches. nominally 3/16 thick.
I fail utterly to manage my camera and grinder at the same time, so I'll have to just write a few quick notes about the initial process:
I generally start with roughing in the handle profile on the contact wheel of my coot, using the knifemaker's rest. For a modern seax style, I then start roughing in a convex grind before doing the spine profile.
The first pass is at 40 grit on a blaze belt, at about 45 degrees an on the platen. this sets my plunge area and gives me a rough guide. If needed, I'll make another pass or two until I'm down to half the stock thickness.
Then I run edge up, pretty steep angle on the slack belt area, until I have an EVEN grind at about nickel thickness. At that point I switch to edge down and make several dozen passes until I've got it all worked out evenly with a good shallow convex.
Then I switch to 80 grit blaze and work it down a bit, edge up and edge down, making everything even as possible.
At this point I'll profile the blade, which magically gives me a slight distal taper. yay!
Then I switch to 120 and 220 grit norton blue belts, which run flatter than the blaze belts. that helps shallow out the convex a bit more.
At this point, all there is to do is run 220 grit by hand, lengthwise. I'll use a hardwood (ipe) sanding block with shop roll 220 grit to hit high spots and smooth out angle transitions, then put a piece of leather between the styick and paper and work it until it's right, and all the belt marks are out (including the plunges)
Then, off to heat treat.
