I used some 1/4" 1084 from Midwest to make a utility style blade. I ground it out with a 2x48 Multitool and heat treated using a propane forced air forge I built. I tested using a 2x4 (nice grade not the soft stuff). Mostly I chopped on the board trying to make it into 6-8 in long pieces, going through the occasional knots and such. I did notice that my geometry did probably hold me up some, from comparing this to chopping with a machete or something very thin. Blade is 6.5" w/ 5" handle, Med height Flat grind (becoming a saber?) and a Convexed edge. Started out with a very sharp edge, not what I keep hunting edges but very sharp. It was hot today so I probably could have gone further but hung it up at a round number.
My results were:
after 6 cuts stopped and checked for rolling, chipping, flat spots, etc in the bright sunlight. No difference noticed. Still Shaving just like when started.
after 8 cuts started to "feel" the shaving characteristics became a little more sensitive to angle. Wanted to dig into skin a little more.
After 10 didn't notice a difference from 8.
After 12 I would rate the edge at about 60% shaving ability of beginning. Still shaving and cutting paper, but more likely to dig into the skin if not held at proper angle. I have handled brand new knives with less of an edge on them, so I wouldn't sharpen it at this point. I expect to see the edge degrade at an exponential rate from this point. From this testing (my first controllable test) I would expect the edge to go around 10 more cuts and be just barely shaving, and at 12 stop shaving.
I finished up with drilling a hole in a 1x4 with the point, which didn't change anything noticeably.
I feel pretty satisfied with this test, it's not rope or cardboard but this is a utility knife not a skinner. I will in the future take it to a full height grind for a little better control in cutting and manipulation. My questions about this are 1: Is this a decent edge holding ability? If not what should I be shooting for?
2: Does anyone else have a benchmark to shoot for?
3: When your blade "stops" cutting rope, what does that mean? Does it then require sawing thru, or does it stop cutting altogether? I see people stop cutting at 30 and some at 100. Is everyone using the same "stop" standard?
Thanks for any input and help. Special Thanks to Doc Shiffer, who generously lent me some time and professional input on my grinds and fit/finish.
Kael Bryant
PS the obligatory Pic
My results were:
Kael Bryant
