Gary Miller Well-Known Member May 27, 2011 #1 i would like to try clay heattreating a a blade. what kind of clay do i use.
franklin Well-Known Member May 27, 2011 #2 gary theres alot out there but i use furnace cement that you get at true value works good easy to get rated at 2700 dagrees, some even make there own.
R Rudy Joly Well-Known Member May 27, 2011 #3 Furnace cement works fine for me. You can use satanite, that's what I originally used but the furnace cement is easier to source at hardware or big box stores. Good luck. Rudy
L Leatherface Well-Known Member May 28, 2011 #5 Gary, make sure you have it even on both sides or its gonna warp
franklin Well-Known Member Jun 10, 2011 #7 you can do a cut out of cardboard and use it on both sides to get even and when applying make sure its of even thickness good luck
