cardoso5fr
A french forumer did a comparison between the fake and the real one. I post that it (i try to translate vaguely) in order to permit to people whose don't have a good knowledge of the balisong worl to avoid to buy a fake at the price of the real BM42. Some dishonnest people have already began to try to sell fake as real......
AldoLeBonze said:The false is on the left, the real on the right.
Packaging is different the copy try to have a "luxuary packaging...."
Open the box
Not the same completion on the handle
The completion of the latch is different. More angle on the copy.
Under the copy latch, no rounded part....
The completion level is poor on the fake.
The blade is not centered correctly on the copy, the completion is at some parsec of the completion level from benchmade.
The logo is etched differently.
...... No comment
The color are different
The grind is not perfectly symetrical.....
Not the same thickness 1
Same thing 2
Same thing 3
Same thing 4
Dismantled....
The tool
Some washer on the fake have been put away, there was 3-4 more by pivot........ to fullfilled the gap between blade and handle.
The numbers
Faux BM 42 ; Vrai BM 42
Total Lenght : 24cm ; 24.1cm
Handle Thickness : 12.1mm ; 13.2mm
Blade Thickness : 2.8mm ; 3.25mm
Weight : 152grs ; 128grs
Pivot Diameter: 3.95mm soit 5/32" ; 4.75mm soit 3/16"
Pivot Highness : 9.4mm ; 9.5mm
Highness under the head : 8mm ; 8mm
Diam int washer : 4.2mm ; 4.9mm
Diam ext washer : 7.35mm ; 9.15mm.
Material
the fake 42 is all steel, blade and handle, the two are magnetic... (difference with a BM42 SS with have un magnetic handle because the stainless steel is austenitic one ....), the screw are also magnetic.
The real 42 have ti handle. and magnetic screw.
Fake normaly in 440C but nothing to check that information....
The real have 154cm blade and ti handle.
I hope that comparison will avoid to some to be "stoled" by dishonnest people which will sale a fake for the price of the real one.....
@ldolebonze
