willows
Hi all, I present my latest creation, a folding knife with locking blade Linerlock (with ball clamp).
K720 Steel blade with high carbon content (59 Hrc). Mirror polished blade. Grips in Corbezzolo root. Folders tempered spring steel. Filework (embroidery on the back of the blade and folders) made entirely by file. Hardened stainless steel shaft and brass rivets. Brass pin on the blade (made by me on the wheel) for easy opening with one hand. Teflon washers.
long when open 20.5 cm - 8.08"
blade length 9.5 cm - 3.74"
closed length 12 cm - 4.73"
blade thickness 3 mm - 0.12"
weight 140 g - 0,31 lb - 4,94 oz
I hope you like
Greetings all
I hope you like
Greetings all
