File Guide
Freds Edge
I made a file guide some time ago , it has carbide inserts that I can't seem to keep glued in place. Has anyone had any experience with this or a glue recommendation , I have been using Gorilla instant glue.
Gliden07
I bought a file guide that the carbide feel off. I contacted maker he said he used a product from Loctite called Insta-Bond?? But he said any good Epoxy should work just make sure its CLEAN. I soaked it in Acetone overnight then used my Foredom tool with a brass wheel and cleaned all of the stuff on it off, put clean Acetone in plastic container and let it sit overnight again. Next day I gloved up and dried it, wiped it off with brake clean and epoxied it with West Systems 12Hr epoxy. Hasn't let go yet? The JB has a little bit higher temp rating so you should be fine. As long as its CLEAN prior to.
C Craft
I used JB weld for a long time. Then one day I dropped the guide and they popped of. I think the constant heat, cool in the dunk bucket while grinding and the combination of the shock when they hit the floor was the culprit.
So I decided to solder them to file guide and haven't looked back!!
Jon Buescher
I’ve tried many different epoxies and go back to JB Weld. Be sure to rough up the steel with a carbide burr and rough up the back side of the carbide with a diamond burr For best results.
I use a diamond wheel on my surface grinder to re-surface them
hey look who finally logged in again
