Hola Knifedogs.
First timer here. Glad to say everything was fine up until this point.
I am now grinding my bevel with a home-made filing jig, and feel as if I am doing something wrong.
I have been going at it for quite some time, but have only gotten as far as you can see in this picture:
I am about half way to my center line, as marked with a drill bit the same thickness as the steel< from where the top edge of the side was when I started. I am using a 1/4 thick piece of 1075.
As you can see in this picture, I have the jig set at ~10 degrees:
I have been going at it for about two hours now. This concerns me because according to this video, in which a similar jig is used, it should take about ~45 minutes to grind down one side.
I think I am messing up. If anyone can point out what I am doing wrong from what I have shared so far, please do.
Any tips on anything else would be appreciated too.
To close, just some more pictures of my set-up that may help y'all figure out if I goofed:
Gracias.
Gracias.
