LRB
Once the main body is silver brazed together in the rear center, or soft soldered with a lap joint, you cut out and shape an oversized top plate. Usually 1/16" thick, or a bit less will do well, but you can go more or less. Sand one side with 220/240 grit paper. Dead true the top of your throat body. Best done by dragging over sand paper on a dead flat surface. Then tin the sanded side of the plate being a little generous with the solder, lay on a piece of flat polished window sill marble, or similar stuff that will with stand heat well. Set the throat down on the plate, flux the inside, heat the outside edges until you see the solder flow. Let cool, and then carefully grind and or file shape the top plate edges as you desire. Then you layout scribed lines where the blade will fit in, drill a few holes and start filing. If using brass, you will find any brass plate thicker than 1/32" quite hard to shape by hand pressure, and better in 22ga or even 24 ga. 1/32" is not very easy, but doable on a large size throat. I do the leather first, then with a spacer or the knife inserted, hand bend and vise pressure the throat metal around the scabbard, and go from there.
		 [/UR
[/UR
