How I Inlay Shields
K R Johnson
As I was getting ready to inlay this shield it occurred to me I might show my method.
I draw a center line on the scale, then a line across that so I have some references when I clamp the template on the scale. If I'm using bone or stag, I use masking tape and draw the lines on that.
Then I clamp the template on the scale with my shop made clamping fixture. There are better ones available from USA Knifemaker but this one works.
Next I set up my Dremel as a router with a 1/16" HSS cutter and since the shield is .040 thick, I use .040 shims under the base and set the cutter so it just rests on the scale.
Take out the shims and cut out the pocket for the shield. The template is hardened so the cutter won't bite into it. Instead of a Dremel, this can be done with a milling machne.
Next I drill a #52 hole all the way through the scale and liner to pin on the shield.
The shield in place after a little careful fitting.
Next I set up a stop on the milling machine so I can drill .020 into the .040 shield through the scale and liner.
The shield is in the pocket on the bottom side and I forgot to take a photo of it but only the tip of the drill cuts into it.
Time to solder a piece of pin stock into the depression on the back side of the shield. This is nickel silver, stainless works too. I use a dab of all in one flux/silver solder, the shield is resting on a piece of soft firebrick, the pin is held in the mill chuck.
The solder melts at 1205F so I turn down the lights and heat to dark red.
http://www.riogrande.com/Product/Silver-Paste-Solder-560-Extra-Easy/103099
Scrape off any excess flux, straighten the pin and it's ready to install.
Cut off the excess pin and pein in place
And sand flush. I did chamfer the hole before installing.
I applied thin super glue around the edge of the shield to fill anything that might need filling and after it dried I ground the shield down flush with the scale. Using this method there can never be a pin showing in the shield like you sometimes see on old knives. I learned this from David Taber who learned it from Enrique Pena. Thanks for looking, I'll be happy to answer questions.
D.Douglas
Thanks Keith. That was On my list of things to get figured out.You explained it beautifully.How and what do you use to sand the shield flush? The templates have to be heat treated before use or do they come hardened already?
K R Johnson
I round off the shield on the belt grinder on a slack belt. All the templates from USA Knifemaker are 1095 and must be hardened.
Jim Moenck
Keith, thanks for reminding me that the shield template needs to be hardened. I would have wrecked mine if you hadn't pointed that out. I need to pull those parts out and start practicing on inlaying shields.
Cubane
I really should try the soldered method. It would let you do things like damascus shields as well without the pins showing.
jeffsaul
Always an enlightening experience to see all the work that goes into making something that's so seemingly simple, but requires so many steps.
Thanx Keith, as usual masterfully done!
Jeff
K R Johnson
Be sure and drill the hole through so if the shield gets stuck (and they will) you'll be able to push it out.
