Hi all,
How long does it typically take you all to hand rub a blade to say 1000 or 1500x?
I'm a newer maker with maybe 9 completed knives under my belt now. I really struggled with hand sanding my first few (taking 10-20 hours per knife and getting less than perfect results when I was done.) Then as time went on (I thought) I got better at grinding and sanding, and 2 of my most recent knives only took a couple of hours each to get a very nice finish that I was quite pleased with. At this stage I thought I had gotten a handle on my sanding technique until...
Now, I am currently trying to finish my latest knife and I'm feeling like I am regressing back to my starting days trying to get a nice finish on it. I must have 15-20 hours into sanding it already and it still isn't satisfactory. This seems like an absurd amount of time to spend on just hand sanding (I'm thinking I ought to be able to build an entire knife in this amount of time.) This knife was my most recently ground blade, so the grinding was decent (and therefore theoretically fairly flat), but it's taking forever and I'm feeling kinda discouraged at this point as I don't feel like I'm getting any better and I don't know what to do differently to get better results.
Sanding methods I've tried are a palm sander, plain micarta sanding block, micarta block with leather glued on, flat mild steel bar, old files, wood dowels, etc. For lubricants I've tried WD-40, Windex, Mobil-1, etc. I alternate direction with each grit, and use 3 different light sources to (hopefully) determine when all previous grit scratches are gone, and I (try to) change paper frequently so that I'm hopefully not using it past when it stops cutting. These techniques seem to work for most other people, but I seem to be struggling with them.
Thanks in advance for any insights!
