FGYT
This is the Parang i've been working on over the last year with UK forces SERE Chief Instructor John Hudson Specifically for their Jungle training courses as the issue Golock is not suitable and the local boght Brunei Parangs have a tendency for their handles to let go of the blades.
first prototypes (Based on the traditional shape but with full tang and G10 scales with Kydex sheaths) for test went well on last years Jungle Instructor course with john and his team the students and even the locals who help and was also tested by Sgt Scott R on exchange from the Australian SERE school.
And a review by :
SGT Scott Robbins
SERE Instructor
RAAF Combat Survival Training School
Sgt Robbins was so pleased he bought the prototype.
we made a few minor changes and a further one of to test this which did well and was approved and i got the order from the Unit for 10 off plus 1 as Johns personal blade)
So last week I finished the first batch of which i delivered just in time for them to fly out this week on this years Instructor Cadre
the blade is now Cerakoted for corrosion resistance
Issue version with Johns (brown sheath grey blade)
they are allowing me to sell this design to any body So Civy sales will partially go towards subsidising sales to military personnel
Hopfylly more in use pics and vid when this lot get back from Brunei in a couple of weeks
ATB
Duncan
And a review by :
SGT Scott Robbins
SERE Instructor
Duncan
First off all, I would like to thank you for the privilege off testing out your blade. So before I go on, I know that John said to you that there was an Aussie Survival Instructor that was keen to play with a blade as well, so sorry for the sort notice and thanks for working so hard to make it all work.
I am posted to the Australian Combat Survival Training School, where we primarily train ADF (Australian Defence Force) Aircrew and other personnel that are prone to isolation or capture in SERE (Survival, Evasion, Resistance and Extraction). We operate in Coastal, Arid and Jungle environments off which Jungle is my favorite. I am currently on a 4 month exchange with DSTO (Defence Survival Training Organization)
So, back to the blade, I tested the blade as you are aware on our recent trip to Brunei whilst instructing on the UK DSTO Jungle Survival CSE.
The first thing I noticed was the sheath.... And the general consensus was that it was awesome. Initially the sheath was a little tight, however this did loosen up slightly as time went on. This being said, at no time did I ever feel that the blade was at risk of being lost. The blade did slide forward in out of the handle crimp to a slightly forward position after jumping off a large deadfall, however in the process of doing this, the blade actually locks in place preventing the blade from falling out.... Don't know if this was intentional, but it works well.
The 3 retaining bolts did break after about 3 days, however being alloy this was likely to happen. I am sure that the steel ones will work fine. So, as a short stop, I lashed the belt bracket back on. This actually worked well. I also like the modular design as this allows individuals to swap the blade from left to right and front or back facing depending on the individual preferances.
So onto the blade. I personally found both weight and balance to be excellent. In Australia, our trees are generally harder than those found in both the UK and Brunei (Bit like the people..... Haaa) so I believe that it will work very well. A couple of the other boys had slightly varying opinions as to if the weight and balance suited them. In all, due to both height, weight variations this in to be expected. The blade held an excellent edge and made short work of all tasks. Over the 2 weeks we really did give the blades a flogging and it handle it all extremely well.
I was also pleasantly pleased with the handle. In the Jungle, handles of blades is both a safety and retention issue. I personally do not use a wrist line whilst using machetes. However wet or dry the slightly larger handle and even larger bulbous end, made retention a breeze. As for balance, I found that having the shank of the blade not sharp worked extremely well when doing finer work. Splitting and debarking performance was excellent. We even cut saplings down, and compared the effort required to cut through the same sapling between different blades. The results were impressive and all agreed that it your blade had better penetration. Good balance of thickness for strength v weight and speed.
So overall, I was extremely impressed with the blade, at the end of 2 weeks of hard Jungle flogging it maintained an excellent edge, and the sheath bedded in great.
I like a full size machete and would be more than happy to replace my current blade with this one.
Brilliant job mate.....
Cheers Scott
ATB
Duncan
