Logo etching
wmhammond
Could someone share with me their opinion of the easiest, least hassle way to etch my makers mark on my knives. Where should I order my stencils and what method/machine should I use? thanks,
Wallace
Wallace, google Ernie Grospitch, he has a website and makes stencils.he's a knifemaker so he knows what your looking for.He's a nice guy and will help you get set up right.
Thanks, I just sent off a email to Mr Grospitch.
Ol' Slatroni just took the words right out of my mouth. "Thanks, I just sent off a email to Mr. Grospitch" . . too
Wallace
hehe, I just got my stencils from Ernie (good guy) working.....before I used something much tougher like thick vinyl. I say that to make the point that, he's not kidding when he says hold the pad on the stencil for 3 second intervals at a time or you'll burn them up quick. Also, the q-tip method seems easier at first, but it's really not in the long run. Make or buy a pad of some sort and you'll be happier in the long run.
I actually use 2 9 volt batteries with wires and alligator clips. Etching solution from USAknifemaker seems to work better than salt water. For my etching pad, since I've got plenty of file scraps hanging around from making file knives, I took the handle end and left about a half inch of the flat portion for the pad. I clip one of the alligator leads to the handle and rap a piece of old t-shirt around the flat to make a pad. It works really well so far.
I say all this as a newish knifemaker who has been trying to keep everything in budget. Yes, I can now say that spending money on the stuff, and/or going to the trouble of using plans like mentioned above is so much better in the long run and if you're seriously going to be doing this for a while.
HA! I tried a HO scale train transformer and it almost worked............... Hey worth a try, HU?
