Hey Ken is real simple to do.
What you need.
1. Wood to clamp it down. I used 3 pieces of 3/4" plywood 4" wide by 12" long. I took two pieces and screwed them together making an L shape, that way you get a back rest when putting your layers down.
2. A couple of medium to large C-clamps.
3. I used Tin foil and some butcher paper, all you really need is some wax paper.
4. Box of disposable plastic gloves.
5. Fiberglass Resin and hardener. I used Bondo's it already comes with the hardener.
6. Blue Jeans cut to 2" wide and 8" long
7. Couple of chip brushes
Place paper on to the wood.
Mix Resin.
Place first strip of blue jean on wood.
Apply resin with brush, get it completely saturated.
Place second strip of blue jean down and brush resin on.
Repeat until you have reached desired thickness.
Pull wax paper over top of the stack of blue jeans.
Place 3rd piece of wood on to stack of blue jeans and clamp down.
You will have resin being squeezed out, so do it over a large piece cardboard.
Let sit over night.
