Lerch
I got in my 1095 steel from Aldo on thursday and after being too busy for most of the weekend i finally got a chance to give this a try. I am using Satanite clay and Parks 50 quench oil. I heated the quench oil in a roaster oven to right at 100deg. I ground the steel and then normalized it as was suggested i do, to do this heated the ground blade to 1450deg once and immediatly air cooled until the blade showed no "heat color" I then repeated this process 2 more times at 1425deg and then cooled the blade to hand temp in air. I then coated the blade with satanite like i saw in Mr. Fowlers tutorial.
Here is the base coat on the blade, this is just a extreemely thin coat over the entire blade
Here is a pic of the top layer of clay, this is right about 1/16" thick
Here is a side view of the knife looking down on the spine. Its 1/8" steel to give you a idea of the thickness of the clay
So all goes as planned at this point and since i know at some point i read that at least one person had success putting the knife in the oven with the clay not fully dry i decided to give it a whirl. Not so good!! lol, the clay blew off the sides when the oven hit 700deg, here is a pic of the mess
So i re did everything and dried the clay in my oven as it cooled down with the door open, about 200-300deg and falling quickly. this time the clay held and i heated the blade at 1450deg for a 5 min soak time and then quenched in the oil. Now when i placed the blade in the quench ( i held the tang out until it went colorless) the satanite was holding on to the blade fine, but at some point when i placed the tang in the oil and when i took the whole thing out the clay came off in perfect sheets on both sides of the blade.
Here is a pic of both sides of the blade after i pulled it out of the oil .
and here is a pic of one of the sides of clay that came off
Well the knife is in the oven now tempering at 400deg for the next 2 hrs. So like i said this is my first try at this and i wont know for sure if i have good tempering lines at least until tomorrow, im curious if any thinks i did anything in particular wrong?? the clay shearing off the sides was a surprise but like i said it held on fine when i was quenching the blade so i would hope that the whole process worked.
thanks
steve
thanks
steve
