Steven Long
Thought I would go ahead and post the way I make a knife. This will be boring to most of you because I got most of these techniques from you guys :biggrin:
This is how I make my Model 1...
Specs...
- 5/32" O1 Tool Steel
- OAL: 8.75"
- Cutting Edge: 4"
- First is to make a pattern of the knife and cut it out from poster board and wipe down the steel I will be using...
- Layout dye spread evenly on the steel and let dry...
- Pattern clamped down and ready to be scribed...
- Next I cut the pattern out on the bandsaw...
- Set up the grinder with the 10" wheel and a used 50 grit ceramic belt...
Specs...
- OAL: 8.75"
- Cutting Edge: 4"
