Plasma cutter
Gliden07
Bought a cheap Plasma cutter. Been wanting one for a while but really forging knives no reason to buy one! Well I finally bought it! LOL! Bestarc Cut-55. So far works fantastic for what I've been doing! No knife stuff with it yet but been doing some metal art stuff as well as Jack-O-Cans for Halloween. Just having so.e fun. It will be great for breaking down larger pieces of stock for knives. They say it will clean cut 1/2" and shear cut 4/5"? IDK if I believe that but it should do everything I want??
Impressive, and I'm impressed at the price also. Isn't this the one you have: https://a.co/d/d2aZEBi
I just spent a few minutes (more than a few:) understanding the difference between the 55A vs 55P vs 55XP and for the $50 or so extra the 55XP sure seems the way to go. Boy, I'd LOVE to order one of those to play with, but I've got a cutting torch rig I've used for many years that does all I really need...... Of course, perhaps a person could attach the Plasma torch to a CNC and do really NICE cutting of patterns?
Dont know if ever will happen but the CNC Table is what i would love to do. One of the reason I didn't get the High Frequency cutter!
I have also been thinking about buying a plasma cutter, but I am a little hesitant as I probably won't use it much after I buy it.
Yeah I get it. I will say the new cheap ones are very resonable. I paid only $160 on Amazon made 4 Jack-O-Cans for Halloween. I sold all the Jack-O-Cans for $45 each and paid for it! Like this one so not even knife related and like I said its paid for.
That's pretty slick - you took a flat sheet metal, cut the pattern, painted the inside black, the outside orange, then Nope, it looks like old propane gas cylinders you cut out? Now that's thinking!
Actually old repurposed refrigerant tanks. Dont have to worry about BOOM! LOL!!
I zoomed in on the top and it does look a bit different than propane tank. Propane tank is the first thing that popped into my mind, lots more familiar with them than refrigerant tanks. Still good job
Im gonna try some propane tanks. I think i may start cutting some tanks for forge kits? IDK if it will be worth it when you can buy one from Vevor for $150ish?? Have to do some research?
The cheap forges I've looked on Amazon leave a good bit to be desired. My thinking is MUCH better to build your own forge - forced air for sure. I've had both, ventura and currently forced air. Better by far. Also by building the burner can be angled sorta "down and rearward" to get full swirling action with the flame. I could lay a 12" billet (maybe a tad more) in my forge and it be a constant orange from end to end without having to move it around. Here's a short video showing the swirl - not sure what the deal is, but that forge has the burner coming in from around 10 O'Clock point and angled rearward.
I used a 30 lb propane tank which seems to be a good size
