A
Allen Rumme
Guest
I’ve been experimenting with stonewashed finishes on skeleton blades and I really like the look. I’d like to use the finish on full tang blades, but it is unclear how one goes about profiling scales that are attached with epoxy without obliterating the stonewashed finish on the exposed part of the tang. The method that I presently use with other finishes is to glue on slightly over-sized scales with plenty of extra epoxy to ensure a good bond, then grind away the excess epoxy and scale material, and then hand sanding and/or buffing things to bring the tang finish back to the same place as the rest of the blade. Unfortunately, that methodology won’t preserve the stonewashed finish on the exposed part of the tang.
I know that some of you here employ stonewashed finishes on full tang blades. Any thoughts on how one might approach preserving the stonewashed finish would be greatly appreciated.
Thanks!
Allen
Thanks!
Allen
