I am about to finish up my second folder and want to put a nice correct edge on it. Currently I am using a belt grinder and do passes up to 600grit. The edge is sharp and looks like a V. When I compare this to a bought knife there are some differences. The bought knife has a taper and then bumps down to a steeper V. I hope this makes sense.
I picked up a lansky sharpening system and would like some help and guidance.
I have not shaped this blade yet, still have heat treating etc to do. Do I continue with what I have done in the past and basically make a V or is there another way. The Belt sander way seems to take out the degree and takes it from .095” to edge. I may just be completely wrong.
Thanks
Thanks
