cardoso5fr
11 cm long, 1 cm thick.19,5 cm long open, 7,5 cm sharp
3mm thick blade 115w8, oil hardened, 200°c tempered (2*30mn). Ta6V4 handle, O1 spring tempered to 340°c. Black G10 scale.
Spyderhole licenced by spyderco.
It's a slip joint on ball bearing. The blade is not perfectly centered closed because i'm a dumb and used a used counterbore mill....The bearing race track is not perfectly square to the flat part of the liner.
That spring is a bit too soft, but that is perfectly functional, i have only to keep a bit more steel at the flex point and i will have the spring strength i want
. I flattened a bit too much too the spring, i have a bit of light between ti and spring (before to have flattened there was a bit of friction of the spring on ti....)
The filework is awfull, i reworked a lot the spring and the top of the blade during the various stage and have eaten the filework. I re fileworked after the Heat Treatment, but that is a bit less easy
Sinon le guillochage est affreux, mais j'ai tellement retouché le ressort aprés TT que j'ai fini par le bouffer et j'ai du le "refaire" sauvagement
The kit
Bad video
http://www.youtube.com/watch?v=iNI6WnCkk7c&list=UUgDVlk-V9TjV7aLkcEGT-Tg&index=1&feature=plcp
The kit
Bad video
