McClellan Made Blades
Good Afternoon Dogs,
I'm attempting my first slip joint folder, so I bought one of the kits from Boss, to get my feet wet. I choose the Swayback Wharncliffe kit, because I LOVE the Wharncliffe look. The pivot that came with it is the threaded type, OK,....let me be clear about this, I'm not dead positive that, that is the one that came with it, I kinda got some parts mixed up, but I think that is the only one I have that will work with the size of blade that goes with it.
My question is, should I use that pivot with it and leave the screws countersunk` into the bolsters, or should I order the type of pivot that is peened into the bolsters? If the screw in type will work I wouldn't mind using them, it'll be a different type of look than normal, OR can I peen the threaded pivot without any problems with longevity or performance?
Thanks Dawgs, YOU ARE THE BEST!!!!
