small washers
Jim Moenck
A while back someone, maybe Ed Caffrey, posted a source for small washers they used to raise an 0-80 button head screw on their folder scales if/when the hole was drilled a bit too deep. I'd like to get some for just that reason. Does anyone have that info that they would pass on?
Thanks if advance.
J. Doyle
Dealer - Purveyor
Thanks if advance.
Just a thought...you could put a drop of super glue in the hole and let it dry hard. Then re drill your clearance hole and carefully reset your depth. It would look less like a mistake (likely not even noticeable) and never fall out.
Sorry I can't help with washers that small.
REK Knives
You can get some micro washers from mcmaster carr I believe... Can't remember if I ordered mine from them or a micro screw/washer site
