Prototype tactical frame lock design. Blade is centered and the lock is bank vault tight. No movement in any direction. The action is smooth enabling the user to either flick the blade open with the thumb or open it in the traditional manner.
Open- 7 1/8 inches
Blade- 2 7/8 inch modified wharnie style with compound ground swedge
Steel- cpm3v X 3/16 thick
HT- In house with dry ice cryo to a tested 59-60rc
Grind- Flat ground to a zero edge
Finish- Bead blasted and acid washed o
Frame- Fluted .210 titanium
Finish Pocket worn with beveled edges
Thumb stud- Titanium anodized blue
Pivot- 3/16 stainless with precision washers and caged stainless bearings
Spacer- Army Green G10 back spacer
Clip- Custom design machined titanium clip with pocket worn finish, Set up for RH tip up carry
Open- 7 1/8 inches
