View attachment 48048View attachment 48047View attachment 48046
Don, i think i might be interested in your system, what does it have other then the variac?
I built the electronics with parts from Radio Shack, as some one mentioned. Enclosed in a RadioShack box with a fuse and switch. Two leads about 18" long with clips for attaching to the ground and the anodizing hanger, aluminum foil wrapped inside the jar as a ground, a hook and holder to hold the blade, and a one gallon glass jar. All operated by switching on the Variac and using the dial on the Variac to change the voltage/color.
I use Cascade dishwasher soap added to the water in the jar.
I'll ship everything except the glass jar.
Give me a few hours to wake up, and I'll send pictures. :3:
OK, here we go. :001_rolleyes::44::44::44:
OK, the first photo shows all the components. Everything goes except the jar. The jar is lined with aluminum foil to act as a ground.
The hanger with the black line attached is a hook made of Ti to hang the parts on. This is the positive connection.
The yellow line attaches to a tab of foil attached to the foil liner. The jar has a rubber shelf liner inside to prevent having the workpiece touch the foil, which will cause a short.
The Variac is very heavy, so shipping this will probably cost 30 or 40 dollars in the U.S.
I don't know if this setup can be used on 220volts, Lerman.
