Wharncliffe. Not perfect but nice.
slatercreek
Hollow ground. Culpepper ivory color bone scales. 3 1/4 closed. 5 3/4 open. Wicked sharp little knife. Might have to keep this one.image.jpgimage.jpgimage.jpg
Nothing wrong with that! Looks great to me. Good job. I do see a slight ring around the pivot pin. I have had that happen to me as well. What I started doing to stop that was to make sure your bolster is completely sanded down to at least 600 grit before peening the pivot pin in place. Don't forget to taper and countersink the hole and then when your done grind the pivot pin excess down using a slightly worn 400 grit belt then back to the 600. Voila! no more lines around the pins. At least it works for me anyway. Just some food for thought.
i love the copper and ivory they just bighten up that beautifully shape blade. love the pattern. great knife.
