What I’ve Learned From Paying More Attention to the Final Grind
B
Black Mamba Knives
Guest
One thing I’ve been paying more attention to lately is how much the final grind changes the way a knife feels. It is easy to spend most of the time thinking about the steel and heat treatment, but two knives made from the same steel can feel completely different once you start looking at the grind, edge geometry, and overall balance. For me, the part that makes the biggest difference is taking the time to look at the blade after heat treatment rather than trying to rush through the finishing stages. A small change in the grind can affect how the knife cuts, how it feels in the hand, and even how the handle and blade seem to balance together. I’ve also found that this is where good lighting helps more than people realize. Looking at the blade from different angles makes it much easier to catch uneven transitions or a grind that looked fine from one direction. The same goes for handles. Getting the scales fitted properly and making sure everything meets cleanly around the tang can make a finished knife feel much more refined without changing the basic design at all.
Curious how other makers here approach the final stages. Do you spend more time checking the grind, handle fit, edge geometry, or overall balance before calling a knife finished?
