Quick knife specs:
Maker: Shirogorov Brothers Workshop
Blade: M390 (60-62 HRC)
Blade length: 109mm (~4.3’’)
Total length: 250mm (~9.8’’)
Blade thickness: 4mm
Blade fix: Liner-lock
Handle material: 3D carbon fiber
Country of origin: Russian Federation
Description:
The 111 is the biggest of the Shirogorov production. It has a blade length of 109mm, a fairly wide handle with carbon detailing, and uses the multi-row bearings system for reduced friction and wear. It flips really well (the knife is superbly centered). The clip is a newer type and is made out of titanium.
The fullers and the steel mark this as one of the top knives the workshop has to offer. You will not be disappointed by the quality and the small details specifically done by the workshop when you take it in your hands. The photos provided are of the original knife currently in stock – this is the knife you will get when you order. Any questions which might arise (including requesting additional photos at a significantly greater fidelity) will be answered via PM or in this thread.
The long handle allows for an ergonomic variable grip for people with hands of any size, there is no bevels or sharp corners on the end of it that could bother your little finger. It can be held both usually and in reverse.
The material is M390 steel, produced by Böhler Bleche GmbH & Co. KG (Austria). It is a steel produced by powder metallurgy – a perspective material for making corrosion-resistant blades which stand up to wear especially well.
The knife comes fully complete, with the box, certificate of authenticity and a special microfiber wipe.
The asking price for this knife is $1000, incl. postage. I will ship internationally.
Description:
