Wayne Coe
Forum Owner - Moderator
For all of you who have wondered or had the question asked and did not know the answer I was able to obtain the use of a tachometer to measure belt speed in feet per minute. I have two Moe's grinders in my shop at the present time. Both use 1750 rpm motors with 4" drive wheels. Each has different size pulleys which is reflected in the chart.
After taking the measurements in Feet Per Minute (fpm) I converted to Inches Per Second (ips) which I think is a more understandable measurement. The formula that I used for the conversion is:
feet X 12 = total inches divided by 60 = inches per second. If someone out there understands this conversion better than I do and if I am incorrect please inform me so that I can correct this thread.
With 1750 rpm motor with step pulleys in feet per minute
4 inch pulley
3.5 inch pulley
2.5 inch pulley
2 actually 1 7/8 pulley
4,000 fpm
2,450 fpm
1,436 fpm
906 fpm
800 ips
490 ips
287 ips
192 ips
5 inch pulley
4 inch pulley
3 inch pulley
2 inch pulley
4,750 fpm
2,475 fpm
1,400 fpm
737 fpm
950 ips
495 ips
280 ips
147 ips
I hope that if you are interested this chart will be useful.
Well the software did not acept my chart so I will make an attachment. View attachment Build A Belt Grinder Belt Speed.pdf
4 inch pulley
3.5 inch pulley
2.5 inch pulley
4,000 fpm
2,450 fpm
1,436 fpm
906 fpm
800 ips
490 ips
287 ips
192 ips
5 inch pulley
4 inch pulley
3 inch pulley
2 inch pulley
4,750 fpm
2,475 fpm
1,400 fpm
737 fpm
950 ips
495 ips
280 ips
147 ips
