Black Walnet Handles
LarryJ
Active Member
heys guys. i am still working on my first design and i have a question. i considered making my hande from Black Walnut. i got plenty and its been aired dried. But i never see anybody else use this wood. Is there a reason its not used or have I just not seen it?
You probably have just not seen it. I have used it on a number of knives. Make sure it is plenty dry...and perhaps send it out to be stabilized if you can.
i also use it at times makes a darn good looking handle and easy to work with. try the supper glue finish on it you will love it.
Nothing wrong with black walnut, but most pieces don't have the heavy grain figure desired for knife handles. Usually you need to find some good dense crotch wood to get the good grain. But, if you are starting out and on a budget, use what you've got as long as it's not a super soft wood (pine, cedar, etc.). Once you get your skills down then you can move on to the more expensive woods or stabilized woods.
I think if you get a good heart piece you will be fine. Looking forward to seeing it when you get going.
Ive bought new old gun stocks that had cracks so couldnt be used for a gun and they can have some awesome grain in it. Like some one said to keep the cost down use the super glue method and it will work just fine. Dryer the better kellyw
Here is one I just made out of Black Walnut. I got the Walnut from My Brother in Law, who had a pile of it sitting in his back yard. I used his chainsaw to cut a slab and then cut a few pieces out of those with a table saw. I used wood hardener in a vacuum to "stabilize" it as best I could. It doesn't have much for pattern but looks pretty good. IMO I have asked him to brine me some more when he comes in a few weeks and I guess I will see if he has any with character. He was just going to use it for fire wood. :) Free is always good.image.jpg
i hear you'all talk about stabilized wood. what is stabilized wood and what is the benfit of having your wood stabilized?
and the super glue method. I guess you talking about gorilla glue to hold the handle to the tang?
No and yes gorilla super glue is used by some and find it to be an excellent glue to use for handles but some dont like the fast setting so use epoxy the slower setting the better. the stuff I use is both gorilla and G2 epoxy . Now stabilized wood can be imitated by placeing several coats of gorilla super glue over the wood and sanded lightly to leave a nice gloss finish I think there is a turtorial here in the tutorial section. Now stabilized wood is placed in a container that can recieve either pressure and or vacume to soak the wood completely through to help solidify and make the wood or ivory or horn stronger harder and polish up better. The results are amazing, I use mostly stabilized wood unless it falls in the rosewood family and they dont need to be stabilized but if they have cracks you can use super glue to fill in any bad spots same with any material. Hope this helps you out.
I think what is meant by the super glue method (at least what I call the super glue method) refers to actually using super glue as the finish on you handle. I recently did a knife with a birdseye maple handle and did a super glue finish on it. I just used original super glue, also called cyanoacrylyte (sp?). This thread http://knifedogs.com/showthread.php?26974-Scraps-from-the-Master-s-Table has some good info on doing this kind of finish. When I did it, I used an old microfiber towel to apply the super glue. Put three or four drops on a little scrap of the towel then wipe it on the handle, covering new area each time you wipe. Once you cover the whole handle, let it dry. Then just repeat until you have...oh...I think I went with ten or fifteen coats. You might need to do some light sanding along the way to knock down the high spots. The key here is light because you can sand through the super glue pretty easily. Make sure to use a high grit paper(800-1000) and have a flat hard sanding stick. This way, you'll only hit the high spots in your finish. When you're done, either buff the finish or use some carnuba wax to finish it for a nice high gloss. Here's a thread with a knife I used a black walnut handle on. http://knifedogs.com/showthread.php?6491-More-Raybar I did a teak oil finish on it. Turned out pretty nice. Post pics when you get your's done!
Peter
tHANKS for all the info guys and I also got my blank made today or my pattern. i took MIG welding welding wire to find the radius i liked and on the butt of the knife i use the bottom of a stirfoom cup for the radius. im feeling like a kid at christmas, enjoying what i got and dont know what im doing yet. now i have got to find a piece of steel i want to use for the knife. im really thinking about just an old saw blade. if or when i screw that material up i wont have any money in it.
Thanks again
Larry,
There are so many advantages to working with a know steel. Get some, 01 or 1084/1095 if you want carbon or go with a piece of good ole 440C to make a stainless blade. If you do the 440c you can send it to me and I will batch with my stainless blades for Heat Treatment.
Laurence
www.rhinoknives.com
Thanks Laurence. i still undecied which steel to use but if i do use 440c i let you know.
thanks again guys
I'd like to pitch in by two cents on steel too if you don't mind. I tried O-1 on a few knives and it is not a beginner steel like many say. One of the knives I did came out of the quench looking like a banana. If you can, spring for a professional heat treat on the O-1. Again, this is my two cents, which is probably about all it's worth. Good luck!
