Von Gruff
I put a pic of the pair of skinners (a mini and a thumbrest) along with the copper bolstered bowie on my FB page (Von Gruff Knives) and one of the gunshops here that carries my knives ordered that same trio so have got them made and sharpened this morning all ready to ship off but during the making of the bowie I thought that some of you may like to see how the bowie comes together.
I had the local engineer make me a mandrel for the drill press that I glue 80 grit emery paper on to match the 2 inch diameter section of steel tube that I mark the curve backed bolsters with
I clamp a piece of 2 inch x 3/8 copper to the tang and drill one hole then put a slip fit steel pin in the hole and drill the second hole. I can then mark the tang dimension on the copper, scribe in the curve back and cut it out roughly with the hacksaw followed by sanding the curve to shape and the front square to the top line. This is then clamped to another piece of copper and the process repeated and with them pinned together that can both be made identical with the front edge polished so it does not have to be touched when the handle is shaped. The copper rivets are spun in the drill press and filed to be a easy slip fit in the drilled holes.
The pins can then be inserted and riveted heavily so they fill out right through the length of the hole s and make for an invisible surface when all is sanded to shape later
The riveted pin heads are cleaned off on the grinder and handle wood chosen and in this case it is a nice set of tambotie scales were chosen.
