I have a carving knife, that has a full flat grind. I took it down to about 20 thousands then heat treated it in a Paragon Oven. The steel is CPM 20cv at .095. I used the direction that I found on the steel manufactures web page. I used the oil quench method. This is my question. I tested the cutting edge using a piece of 1/4 inch hot rolled round rod.. I held the knife at and angle and pressed down hoping that it would not snap and that it would flex back. It did not snap or chip, but it did not flex back. It left a little dimple. I did this test after I finished grinding the full flat edge. Can this knife be saved. If so I would love some help from you guys on how to do it. I have a hardness tester arriving at the end of this week and will test the knife. I do not think that it will do me any good to know the hardness at the handle when the edge is the problem. One thing that I may have done was overheat the edge when I finished the grind. I do know that it was hard to grind after hardening. I am hoping to learn from this mistake, when someone one here point it out. Thanks.
