I understand more...now that you mention the forge used. It's really tough to do something like that if the forge is too small....meaning that there isn't enough heat.
Ribbon burners are certainly a viable option! You just have to ensure you have the fuel supply to run them. Ribbon burners take a LOT of volume, which means if you're running a 20lb bottle, it's just not gona cut it for "canister welding". The bottle would freeze up in mid stream....and whatever is in the forge would be a train wreck. I would say that the minimum you'd want for a ribbon burner is a 100lb bottle, and better yet a large outdoor tank. (my shop has a 500gal tank that is piped in, and runs the forges..... it's very economical in that it only requires filling about once every 12-16 months) If you have all the things needed,
Personally, I'm fond of a single, blown burner, which is sized properly for the forge body it's used in. My welding forge, which is a vertical oval design.... with an interior that is 16" tall, 18" fron to back, and 10" side to side. The burner is a 164cfm blower (built for a forge), with 2" pipe coming out of the blower, into a 2' X 1 1/2" 90 degree elbow, and then to a 1 1/2" X 18" pipe, which goes into the forge. Because the forge is so big, it takes it a good 2 hours to heat to 2350F....but once there, I have to keep dialing it down to keep it under 2400F!
