Lerch
After a bit of failure on my first try i was successful the second time around trying to differentially harden and blade and produce a hamon. The steel is Aldo's 1095 1/8", i ground the blade to about .040" on the blade since after my first experience i knew i needed to leave it a little thick to account for the scale and decarb removal.  Anyway i ground the blade to 320grit and then normalized it in 3 cycles.  After this i ground the blade to 400grit to remove any of the scale left over from the normalization.  I then applied the satanite clay and HT'ed at 1450deg for a 5 min soak time and quenched in Parks 50 oil heated to 110deg.  I cleaned the blade off and tempered at 400deg for 2hrs.
after sanding to 700grit i could see the hamon if i turned the blade in the right light. I sanded the blade to 15000grit and then after a series of 30 second to 1 minute etches in PCB Etchant (Ferric Chloride) i was fairly happy with the temper lines but decided to try something just a bit more. I sanded the blade down to 2000grit and etched for 2min straight, wiped down the blade with windex and then placed it in my Lyman brass ammo tumbler with pecan hull media for about 2hrs. These are the results, im pretty happy with it. After HT'ing the blade i read where certain steels produce temper lines either behind, on or before the clay line and 1095 tends to produce a temper line before the clay edge which is why you see the temper lines so close to the blade edge, i will take that in to consideration next time around. any way here are the pics
let me know what you think or how i can improve, cant wait to try it on a bigger blade, this one is only about 3"
thanks
steve
thanks
steve
