Rocko,
The Coote was my first Real Grinder and if you can make knife? You should be able to set up a grinder.
www.cootegrinder.com I still have mine 15 years later. A 1 1/2 - 2HP motor and the pulleys with some link belt and your have enough to be a professional maker, as far as the grinder is concerned.
the rest is up to you.
Every machine has a few draw backs. Tracking is NOT one of them with the Coote.
Also Norman Coote is a great and helpful man. Call him with any questions.
My flagship grinder that I would buy again over 95% plus of the current stuff on the market budget allowing is my
http://www.hardcore-products.com
Mine is machined Aluminum and is very quiet and smooth right out of the box!!!
They now make it in a cast Aluminum that is every bit as fine of a machine.
"Get the variable speed 1 1/2 - 2 HP" My machine has never even burped on me!
I had it rebuilt at a bit over 10 years of heavy almost daily use. The machine was fine!
It was the Baldor motor that took a dump on me and I told them to go through the grinder while they had it apart.
The other machine you might look at is the new TW-90 Google TW-90 and Travis's machine will come up. This and the Burrking are the two machines.
I would consider for a fourth machine in my shop. A Bader for the right price maybe?
I own and use a KMG in my shop too, but I personally wouldn't buy another because by the time I added all the upgrades I needed to it I was in the price range of buying another Hardcore grinder.
The one thing that the Bader/KMG configuration does better than the Hardcore or Coote is small wheel work due to have the belt wrap around the small wheel much tighter in angle.
So that's my 2 cents here on the Grinder question.
Laurence
www.rhinoknives.com
