Johnny Roberts
How do some of you get your scales flat?
As I have progressed to combining different materials and types of wood for my handles, I have been sanding the side that will be positioned against the full tang blades. I have a big piece of marble and I tape down some 12 X 12 inch sandpaper and pull the scales from the far sided to me.
I get a great finish but sometimes the scales may not be an even thickness when I am done. They may be slightly thinner on one side or end. As I user spacer materials and angled joints, these differences become even more visable.
It is not a super big deal since I can usually correct it. Sometimes, it is no issue at all since after my scales are attached, I am working the handles to the same thickness with files and my slack belt attachment.
But I am thinking there has to be a better way to get symetrical flat scales.
I bought a small Delta Planer but the contact wheels were just barely more than five inches apart and it actually would leave low spots on the scales when the second drive wheel would pick up the block. (I usually work with scales that are exactly 5 inches long and you could see the scale wobble as one contact wheel grabbed it and the other one let go. This did not occur on longer boards.) I tried it on another 2500 dollar planer and got similar results. In fact, it was worse.
Any suggestions? I have tried the flat platen and disk sander but the higher speed seems to mean bigger mistakes to fix back on the sandpaper for me. I have also seen the Micro Planer but at 700 bucks for a machine that I may use once a week?
School me, fellow knife makers and many thanks.
Johnny "Stay on the low side of the buffer." Roberts
