Here is a product some of you guys may have a use for, you can get it at Brownells it is Gun-sav'r gunstock finish. I have used it on a wood japanese sword case and the walnut scales on a folder, am very pleased with the results. Comes in spray can will run and tends to build up around holes and on the edges, takes a little fooling with, need to give it time to dry all the way thrue. Sanded it wet with 2500 grit, polished it with 3M boat rubbing compound, gives a nice smooth polished finish. Deane
