Lerch
I have been trying to figure out a way to really make the temper lines or hamon show up on some 52100 blades while still having a mirror finish.
My current method has been to achieve a mirror finish ending with a loose flap wheel and green chrome polish. After this is have etched the blades in ferric chloride for 15min and then cleaned them off with dial soap. using Flitz i clean off pretty much all of the oxides until at least the hardenend edge is back to a dull mirror finish and you can see the mulitiple quench lines. At this point is where im kind of lost. IF i continue to polish with flitz i eventually lose the ability to see the temper lines but i am still able to see the darker (cloudy) softer portion of the blade and if i take the blade back to my buffer i get pretty much the same results just with more of a mirror finish on the hardened edge and the same cloudy portion on the spine.
What i would ideally like to get is pretty much what i have now but with of a visible temper line and i was just wondering if there was some trick i was missing. i will try to include a pic of one of the blades tomorrow.
thanks
steve
thanks
steve
