J- Weight Belt Option
D. Crawford
Last week while ordering belts from Pop's I started to order some
J-flex belts. Like most I like the high flex backing but the belts are
pretty short-lived. I saw Pop had another J weight belt from 3M
so I ordered some. If you have never tried the 3M Regalite 707E
you owe it to yourself to try it out. Only very slightly stiffer than the
Klingspor (which should keep it from curling) but it's a ceramic belt
with a seemingly cleaner cut and much longer lasting. Price is right too.
I was really impressed and wanted to pass it on since I don't see it
mentioned very often.
Hope this helps someone,
David
Sure wish I'd seen this 30 seconds ago, I just finished an order with him too! I'll give them a try next go-round,
you're in east Tx, I'm in Central Alabama, you just think you know what humidity is! I've had freakin BLAZE belts curl!!!! I don't use too many J weight belts, I HATE THEM CURLY JEWELS!!! If I need to get in close I generally will split one of the others I already have and make it 1" or whatever size I need, after doing that to several of them, I just save both sides and they eventually get used. I have heard of some folks using heavy cardboard tubes to hang on the bottom of them to keep them straight, I haven't tried it yet and winter is creeping in so it shouldn't be too bad
until March. But I'll definitly give them a try, when I order again, Thanks for the tip! Rex
