Justin Presson
Just thought I would share this with you guys as a learning experience.
I had a gut feeling that one out of the 4 bowies I'm working on may have not properly hardened. As you can clearly see in the picture I only got about 3" of the edge from ricasso to tip to harden.
This was the second blade I quenched. I was using canola oil and after I had quenched this blade it felt like towards the tip the file did not skate as well as it should have. I checked my oil temp and it was 125 degrees before I quenched the first blade, after the second blade(this blade) I checked it and it was at 180 degrees. I added 2 more gallons, removed it from the burner and it cooled back down to 125 or so before I quenched the other 2. I checked in between my other quenches to make sure I was withing range so hopefully 3 of the 4 were successful.
Just thought I would share. I have got to purchase some parks in the future here.
Hey at least I practiced on grinding in fullers on this one before I do the other 3.
