ddavelarsen
Wow a DC 1.5 HP motor should be any thing but easy to bog even with a big flat wheel. I am curious about your controller. Does it have IR compensation adjustment? If so you might try tweaking it a bit. It might be worth wile for you to upgrade your controller. A DC motor with good controller will maintain constant speed very well and the lower the speed the higher the torque, at least in theory. Of coarse you could just be over powering the motor
You might have something there. It's an older machine, not a digital controller. Thanks, I will consider that.
