Tom Anderson
Artistry in Titanium
This was originally posted online in 2002, but it was lost - so I resurrected the photos and added new text....
Starting with the drawing:
I use CAD to design knives, but you don't have to. Regardless, it's a lot easier to make your first frame-lock folder after you have a drawing that shows all the major components with the blade in both the open and closed positions. I do this with every model folder I make - even when I'm simply changing the size of the knife.
With the drawing developed, you can use scissors to cut out the blade and the frame outlines, glue them to some 1/8" thick Micarta, and then cut out Micarta templates.
Here are the Micarta templates, sanded to shape with the holes for the pivot and stop pin drilled, along with mounting holes for the round spacers I'm going to use.
To make sure the templates fit together properly, I install some pins and swing the two parts open and closed to make sure the blade stops where it's supposed to stop.
You can see I've even added the thumb stud and round spacers at the back to make sure the blade doesn't hit them when the knife is closed. (I'm going to use the same size spacers and thumb stud in the finished knife.)
With the templates made and proven, you can now use them to lay out the material. Here, I'm using an Ultra Fine Sharpie marker to layout a sheet of titanium for sawing.
