Well, it wouldn't be easy to put down in a few paragraphs. I've been working with titanium for 15 years and I'm still learning how to cut it.
I can offer a few basic recommendations, based on my experience...
Always reduce the speed as compared to working with carbon steel. Titanium retains heat. Heat destroys most cutters and abrasives.
Use cobalt drills. The one's with a 135° split point seem to work best.
Use ceramic coated abrasives and don't force the work piece. If you start seeing white powder on the part, slow down and put on a new belt. Titanium oxide (that white stuff) is dangerous.
Some makers friction cut titanium at high speeds, but I like to use bimetal band saw blades with a staggered pitch. The number of teeth required depends on the thickness of the material you're cutting. I set the speed at 100 fpm or so.
I prefer carbide end mills and carbide lathe inserts. They seem to last longer than high speed tools, although alloyed titanium (ex: 6AL4V) is hard on any type of cutter. Interrupted cuts especially break lots of tools.
60% threads are easier to cut than 70% threads, so adjust your tap drill sizes accordingly. Titanium wraps around the teeth of taps. Also remember to go slow and use plenty of lubricant. If you go fast, the tap will wear, and the titanium will heat up. You could end up locking the tap inside the hole. Go slow and use plenty of lubricant.
Every make you ask is going to have different opinions based on his or her experience. I've tried things that seem to work for other makers and ended up just wasting time, tools, and materials. It's all part of the learning experience.
