Drew Riley
Are they getting too hot to touch?
Ah... that's definitely too hot.
Could be that you need a slightly wider spacer inbetween the bearings. Sounds like they might be binding.
interesting you can't find a spot where the wheel is loose enough to turn freely without heating up, and the wheel still track - this is a platen wheel? I can usually loosen the axle nut on either of my platen wheels a good bit, maybe even remove the nut and still run the grinder a bit without an issue. Tracking is usually a function of the tracking wheel rather than the platen wheel.
I can't suggest an answer now<
Ken
I think he's referring to the spacers between the bearings- this spacer fits inside the wheel to prevent those bushing you are referring to from pressing the bearings to the wheel too much. To check, back off the axle nut a tad to see if it runs cooler.
Ken
