The easiest way (as opposed to the best way, which I don't actually know) to make a functioning sen (I borrowed liberally from Walter Sorrells and his videos to do this). Here it is:
1. take an old file.
2. grind the teeth off until it really is smooth.
3. be careful with heat, so you don't ruin the temper of the steel while grinding. You want this tool to be just as hard as the file was.
4. grind the bottom flat (what will be the bottom) smooth with a magnet holding it against the platen.
5. polish to about 400 grit on grinder.
6. cut between a 75-85 degree angle on what you want to be the leading cutting edge. You can flat grind it, convex, or concave. I have had best luck with full flat and hollow. Full flat is easiest. Turn the grinder way down, tip the file about 5-10 degrees off of exactly perpendicular to the platen (i.e., tilt the rest or the platen, it works better than grinding by hand).
7. polish the bevel on the machine with about 400 grit belt.
8. go to work... you will need to tilt the scraper just a little, and work with the angles until you find the one that works best. I also find that holding at a little diagonal across the work rather than perpendicular as I am scraping works better.
I used a sen I made in 3 minutes to do some scraping on this blade. The simple way I learned from Walter's vids is great because you can make and touch-up in almost no time.
