On full tang knives, how do you remove the Tru-Oil from the finger guard/bolster and tang without removing the gloss finish of the Tru-Oil on the scales? My only solution is to use 0000 steel wool on the entire handle, apply some wax and then buff with pink scratchless compound. I get a semi-gloss but it's not the deep luster like the original Tru-Oil finish. I've tried taping off the wood and then use steel wool on the metal but I end up hitting some of the wood anyway. Any suggestions?
