way, way, way, way better than my second knife. My second knife looked like a butter knife with a stacked leather handle. I ground the point off somewhat because I am not very smart.
Here is one hint that will help a lot.
If you post your pictures on something like Picasa, you can then generate a link to the image (make sure you generate a link to the full size image, and use the "image only, no link," option.
Then, when you type your post, when you get to the point where you want to add a picture, go to the toolbar and you will see an icon for, "insert image." click on that, make sure it is expecting you to insert one from a url, and then paste the image code in you got from picasa. I say Picasa because its free and doesn't give the advertisements and crap of photobucket.
This will put the picture directly in your post, and it makes it so that you don't have to deal with trying to click on a thumbnail and open it to see it.
Also, if you type your post with the pics inserted this way, you can copy the entire post before you submit it. You can then post the same basic thing on any other forum you use, and the images and everything will be there automatically. So, if you post on a couple of forums, you can get your initial post done easily for each new knife on the second forum.
Last thing, if you take closer pics, we may be able to give some helpful hints. Although, you seem to be off and running. There are always tips that we can share among ourselves.
hope you don't mind the suggestions. They are just suggestions. If you look around, you will notice pretty much everyone else posts this way. It took me 3 years to figure it out.
take care,
Kevin
