kybruce500
Member
can a san nai be forge were stainless is the mode metal for a shiny edge & dark spine ?
I think he is talking about using Stainless as the cutting edge and having a steel outer shell?kybruce, where are you located? Your profile doesn't have any info. Filling it out helps folks know the area you're in and able to offer more help to you.
Are you talking about using SS for the outside cladding with a high carbon steel for core so the outside is shiny with a dark core? Something like this folder I've started?:
That is 416SS cladding with 1095 core. There are several folks around who do SS San Mai. I like it better than using carbon on both places, but is a tad tricky to make.
I found that out the hard way when I tried a Go-mai with two layers of 4xx series stainless. I suspected the stainless was the cause of my failure though I was too embarrassed to ask.The issue is that the vast majority of those will simply not forge weld,
Did not do that either. Tack welds only. Man, I was doomed from the start. I just treated like any other steel.For forge welding SS it needs to be seal welded all the way around the billet.
First allow me to say I am NOT an expert at all on any type of forge welding. I've done a few billets of San Mai, both SS cladding and carbon clad, and a single low layer Damascus. I have done a LOT of reading and talking (writing) with other experts like Devin Thomas (Hoss) and his son Larrin on the subject. What I have learned confirms what Ed says above that any hardenable SS is fairly difficult to forge weld, or even forge to shape. The only time I tried AEB-L as a cladding was a test. While it did forge weld, it cracked big time. Devin says to make it well the temperature must be controlled very close.If you're asking about stainless being the edge/core material, generally the answer is NO. The reason? To create a hardenable, usable, San-Mai blade with stainless at the core....the core would have to be an austinizing stainless....meaning a hardenable/heat treatable type. That would generally mean a stainless in the 400 series, such as 420, 440, etc. Or another hardenable stainless.
