Thoughts on a motor
There should be a lug inside the motor for the ground there will not be a wire. All the ground will do is take your bare or Green wire and ground it to the metal case of the motor. If there is not a ground lug inside the wire compartment you should be able to attach the wire from your cord to the compartmant screws. Just get a crimp on terminal of the appropriate size.
I am confused about what you are saying? Yes there is a ground lug but I thought there had to be a wire to put the lug over to ground everything. I do not see a ground wire that would go on the lug.
